JP / MidOHasp...keep working your check list as rest assured that radiator in your SPF will handle 520 or more cubes for cooling efficiency...my bet is your problem aint the radiator, but one or more of the items on your check list. The cooling capacity on the SPFs is great, when there is a problem it is engine related, or underdrive pulleys, or wrong pulley ratio, or bad stat or bad water pump...but NOT the radiator. good luck, bill, spf156
