Old 07-28-2003, 01:52 PM
JohnM JohnM is offline
Default March & Finish Line info
Hello All,
I called Finish Line and talked to Enzo, his aluminum tank will not work with the typical March alternater bracket that has the tension rod going up from the water pump to the alternator.
I called March, they have a bracket and tension rod that spins the altermator down, and the tension rod will be out of the way
Part #30395 for a 351W driver side outlet on the water pump
Cost $111.04 Sounds like the way to go if you want an expansion tank at the front of the manifold
John
