Old 07-28-2003, 05:50 PM
MidOHasp MidOHasp is offline
Cobra Make, Engine: SPF1670 Stroked Little Windsor - Runs OK.
Send a message via AIM to MidOHasp
If you like the look of the shorter covers, pull the baffles out of them, use a socket and a hammer to knock some depressions in for the rocker studs, and grind off all the casting crap on the inside. They're only a "little" too short to fit over rollers. I spent 2 hours working on mine (an hour a piece) and they fit fine over some big ol' rockers and studs. I like the look of the short ones and that's why I spent the time. But to each his own, for sure. 'sup to you, but you CAN use the shorter covers. Just takes a little massaging and coersion.
J.P.
Ohio Cobra Club
Token Gashole
