Vizard comparison chart
because I live in the industrial N.E. I will continue to use Motorcraft paper filters on my vehicles, IF u are concerned about flow, just increase the size of filter. example 12" dia. to 14" dia..or if space permits 3" height to 4" height...also a tip most engines are running an air cleaner too close to the top of the (Holley)choke shroud...ordinarily milling this off will give an increase of only 12cfm...BUT if U were running an aftermarket unit because of hood constraints, milling the shroud off in this instance will yield up to 150cfm..the difference here is unbelievable!
69 Mach 1,428SCJ trak pak,4 speed, 3:91 axle restored
