Old 07-29-2003, 11:11 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Just a note: Don't use a hi-volume oil pump. They waste power by pumping more oil than the engine requires. As for under-drive pulleys, the oil pump is not affected, but the water pump sure is. If cooling is marginal, it won't be if you go to a slow water pump, so I recommend that you stay with the stock stuff at first, then make a decision.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
