PCV for 351W
Hi Guys,
I'm using a 1969 351W and would like to know what you guys have found to be the best way to vent the crankcase. The breather cap I am using has a short pipe fitting for a vent hose. Should I place the PCV Valve between that breather fitting and the air filter or should I go for Carb vacuum or manifold vacuum?
I am using a Raod Demon carb and there is a vacuum pipe at the rear base of the carb. I also have a threaded port for a vacuum fitting on the rear portion of the Edelbrock Performer RPM manifold.
Any ideas, advice, or suggestions, as always will be greatly appreciated.
Tony
