Old 07-30-2003, 12:02 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Try it without the rev limiter chip and remove aircleaner.
If not that, I'd guess valvesprings are weak and floating the valves.
I am assuming you allready gave it an ignition tune up by replacing the sparkplugs, cap, and rotor. Checked the plug wires, and the coil is OK.
