Fuel delivery
You must look at not only the fuel pressure, but also the hose/line sizing in order to determine weather or not you are starving the engine. You may have 6psi in an 1/8th inch line, but it still will not be able to deliver the volume of fuel necessary at the high RPM. Make sure there are no restrictions in the fuel filter or the carb inlets.
