Old 07-31-2003, 07:16 AM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Sorry for the confusion - I'll restate it:
If I put the 6000 chip in, it will start and run for a max of about 30 seconds then die. If I goose the throttle, it will respond, but not stay going. If I play with the choke, same result. The "idle" is somewhere around 3500-4000 (guess).
With the 3000 chip, it will start and run continuously, but will not come down off of the rev limit.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
