Old 08-01-2003, 03:29 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
One other out of the way thought. Have you done any recent work to the engine....like changing manifolds or thermostat housings? Years ago I had some silicone squeeze out from a gasket and get stuck in the water passages......caused me much grief until I finally got it out... I'm sure what you have is something common, but if all else fails you might have to start looking for the not so obvious problems..
