08-01-2003, 02:37 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
Correct front end track
Can anyone tell me what the correct track for the front end of a CR is? I recently purchased some Compomotive wheels and tires from a member here and am wondering about the backspacing on the front wheels. They're wider than most....9.5" I believe and have 5.5" backspacing. They look close...( could possibly be a little wider or have a little less backspace), and I end up with about a 53" distance from the center of the tread on one wheel to the center of the tread on the other. Is that about right or should they be wider?
Thanks,
Bill
