Old 08-01-2003, 07:14 PM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
TT...a later year block is easier to use a roller cam in. Earlier blocks from the late 60s and early 70s have a shorter lifter bore and you'll either need to use a specially ground smaller base circle cam or use Crane link bar lifters that are shorter than stock Ford lifters....It's a much more expensive proposition than using all stock Ford roller cam accesories with a later block that already had a roller cam.
Shawn... Expect to see well over 500 reliable HP out of a stroker without to much trouble at all.....and yet it will still be very streetable..
