fxbill,
I love the last line of your "byline"!
The nose does look a little high. Look at the front springs and try and determine if they have already been cut. The original manual had you cutting a full 3/4 out of the fronts. Ground clearance on the nose, on level ground should be around 4 1/2 to 5"s.
With your motor and using a stock front end, if you decide to drop it anymore...go slow...a little cut goes a long way!
DV...Fx-does your car launch "hard left" on a three thousand RPM launch? I can help!
