Old 08-04-2003, 10:48 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I run 750 DP's on all stroker small blocks. You need to get different shaped floats in your bowls. Yours are probubly rectangle shaped, you need the ones with the lower corners removed so they have a trapezoidal shape, that way the needle and seat doesn't get closed when the fuel sloshes to the sides of the float bowls. You can cut and trim the Nitrophil floats, but you will need to seal the foam with epoxy where it is trimmed, it is easier to just buy floats with the shape you allready want.
