Old 08-04-2003, 11:40 AM
fxbill's Avatar
fxbill fxbill is offline
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I know the 94-97 fuel injected 351s had roller cams, but I'm not sure about other years. Ford dealers could give you a solid answer..
