Old 08-04-2003, 11:44 AM
Mike Braddock Mike Braddock is offline
The windsor and cleveland heads have identical port spacing. But the port shape and exhaust flange (head) angle is different, so the collector will not be located in the same location. Your signature says you're running a cleavor--a W block with C heads. Again, due the difference in deck height, the collector will not be in the same location when you finish.
Mike
