Old 08-04-2003, 12:58 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Having a 750 instead of a 650 will have only this effect: slight loss of throttle response at lower RPM's and less chance of a few lost HP at the top of the RPM's. Stumbling, idle quality, etc will not be affected.
WB: how far turned out are your idle screws?
Is it possible you have a blown (or incorrect) power valve?
Under what conditions did your motor run awful after putting in 68's?
