Old 08-04-2003, 01:39 PM
WBofTN's Avatar
WBofTN WBofTN is offline
Roscoe:
I have a 650 on an old ford truck, but it does not
have duel fuel feeds and it would require to much
work to remove and reinstall.
Mr fixit:
I set my idle just under that that resonating sound that
hurts you ears - (cant remember the rpm) If that helps.
With the 68s in, the car was stumbling during acceleration.
But it was not running as rich. Like I said early, with the 71h(s)
in the car runs very smooth and pull so hard its scary. Maybe
this motor is not ment to idle of run slow.
On the plus side I have not fouled a plug in 600 miles.
How do you tell if your power valve is wrong or blown?
WB
