TK, this may sound really stupid but it's worth a look. The Lone Star car was originally very close to the Classic Roadsters. On the Classic car the front sway bar can be put in upside down which will make the front suspension almost solid. If you have a sway bar I would check the installation and make sure you do have travel. On the Classic car it is obvious when it's installed wrong but you don't know it untill you have no suspension travel. On the Classic car I use a 375 lb coilover spring on the front and a 250 on the back. Good luck.
Don
