Hey Dave,
After I wrote that I thought nobody is going to understand what the heck I was talking about. I am building the shroud that goes in the front of the car, in the nose (the grill) up to the Radiator. It stops the air from going around the Radiator, and seals off the noise when you look in the front of the car. It is hot here in AZ, and I was hoping that this would solve some cooling problems. The shroud has the
oil cooler lines sticking up from the bottom, and they also come in from the sides of the shroud. I hope this helps. I called Lone Star, but Dennis has not returned my calls....? I am interested in how this goes up to the radiator, and is secured to the body/Car. I could use photos of how the hinges for the hood go through the sheet Aluminum???
Thanks for the help!!
Brian
