Thread: Torque Straps?
Old 08-05-2003, 11:47 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
you can put as bolt and two fender washers through most motor mounts to make it less stretchy. An aluminum flywheel will make the biggest improvement in eliminating motor torque-over, excluding solid motor mounts. If you use a chain as a torque strap, it will stretch and become worthless in a very short amount of time.
