Old 08-06-2003, 07:35 AM
BPWilliams's Avatar
BPWilliams BPWilliams is offline
Cobra Make, Engine: none
I am not sure how complicated the pedal assembly is, but I am a certified welder, own a lonestar, and have Gas, and Arc capabilities. If you aare not in a rush I can Tig at work. If you have the same set-up as me, it is the Tilton brake/clutch assembly. That assembly is made of steel so it should not be hard to modify. If you are looking for a shop try Anthem, or G. Levy......
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
