Old 08-06-2003, 12:09 PM
DAVID GAGNARD's Avatar
Question??????
This fall or winter I will be building another motor. So far,these are my plans;
351-W block (1970) .030 bore
forged flat top pistons
Aftermarket rods (h-beam or I-beam have not decided)\
cam will be solid roller,lift in the 550 to 575 range
compression will be no more than 12 to 1
roller rockers
aluminum heads AFR....
This motor will be a strictly race motor for a Vintage race car turning probably no more than 6500 rpms.
Question is which AFR heads,185s or the 205s????Which would you recommend????
David
DAVID GAGNARD
