Thread: Ignition?
Old 08-09-2003, 08:16 AM
aumoore's Avatar
aumoore aumoore is offline
Cobra Make, Engine: Hunter 427, 5.0 (302)
If you check out the MSD stuff you will find a few failures especially the MSD ignition boxes.
From what I have been told by people that run Mallory Unilights you have to be extra careful when welding or jumping off a Unilight equiped engine. Always disconnect the ignition before welding on the car or charging the car. Never jump start a car with a Mallory Ignition. Charge the battery with the cables disconnected. The LEd in a Unilight is very sensitive to power spikes.
Many Unilights are damaged by hooking up wrong or by not using a ballast resistor. If you run a Hyfire box you do not need the ballast resistor.
I have seen many MSD failures and I would not recommend jump starting any modern electronic ignition cars.
I have ran my Mallory Unilight for over two years and many of the miles are under road race conditions. Drove the car from Pensacola to Ocala, Florida in 5 hours and back the next day. Never a hickup.
Take care of it and it will give good service. Maybe MSD has less failures because there is less of them on the road? Mallory has been around a long time and they make OEM ignitions for Boat manufactures.
Don't get me wrong MSD makes good stuff but they are not the only option out there.
Click here for DSCC website
