Thread
Cam Selection
17
permalink
08-10-2003, 06:02 AM
RICK LAKE
Funfer2 Hi Kevin. Couple of things. With whatever cam you put in the motor, make sure the valves DON'T hit the pistons. you need a .120 clearance one and .100 on the other one. You can get a hydro cam with .550"-.560" have a nice loping idle and low maintainance. You can have a roller cam make for your motor. Hydrolic or solid rollors. I have a .501-533. cam in a 452 motor, 9.2-1 compression CNC heads and single plane manifold. my numbers are 340 hp 428 tor. at the rear wheels on a dyno. I can run 13's in the quarter. Car runs great, nice 750 rpm idle with alittle lope. I donot have to pull valve covers every months to lash valves. Are you going racing every weekend??? Save your money, buy the alumium heads put a small cam in it and build another animal motor. 13-1, 700 lift cam, race fuel. Build a tork motor with 500-500 lbs, this is all the car will work with. Car wieghts 2500 lbs. You need to go for a drive in someone elses car with and ask about how much maintainance is needed. Bigger is not always better.
sometimes small is just RIGHT. Rick Lake
RICK LAKE
View Public Profile
Find all posts by RICK LAKE
