Thread: Runnin' Hot
Old 08-12-2003, 11:31 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default After draining the original 50/50 fill
And replacing with distilled water and 2 bottles of Water Wetter... and installing a new 180 thermostat, with a small hole drilled in there to bleed air...
My water temp is now generally 180 to 205, (before was going to 230+ and the oil was getting way up there too) unless I get on it, then it climbs fast, so far not above 220 tho it does cool down slowly unless I get on the highway. The car was delivered with the 7 core radiator, the stock ford pump (high polished) with a HUGE 6.5 inch diameter billet aluminum WP pulley.
I will soon do the following:
~ 5 inch pulley (will this adversely affect my power assist steering pump?)
Switching to synthetic oil.. am told, but am skeptical, that this will help my 514 run cooler, due to lower friction. I need to get at least 3500 break-in miles on her before I even consider that.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
