More bad luck? Hard to believe. What you need is a well-sorted car with a history of reliability. The process of getting your car to this point has been really challenging. Your friends are with you though. Stay strong.
I once saw a large oval air cleaner that actually sat on top of the plug wire where it snapped into the distributor cap. Eventually it rubbed the wire enough that the spark began diverting to the air cleaner base rather than travelling to the plug. Sometimes really hokey stuff can happen on these cars. You may find the solution is simple. Good luck.
When I said I wanted to be somebody, I probably should have been more specific...
