Have you checked your valve rocker geometry?Are the adjustment screws really backed up so the ball end is close to the arm?Are the rocker shaft stands the right height (too tall) so the cup on the pushrod isn't getting too close to the arm on full lift?A change in height will reguire a change in pushrod length.Stiil no big problem.Customs are available from an outfit in Oregon.
Mike H
