  #39 (permalink)
Old 08-15-2003, 02:16 PM
Brent Mills's Avatar
Brent Mills Brent Mills is offline
Administrator
I'll have to check the clearances this weekend. Getting the sucker towed home from my work parking garage tonight.
Things I plan to do:
1. Check clearance between cup and rocker at various points of rocker travel.
2. Leak down test (hoping intake valve didn't get buggered up).
3. Probably order a set of Precision Oil Pumps rocker arms which I got the shaft, spacers, and supports from. They use a ball-ball pushrod which will help if there were clearance problems.
4. Order top line push rods.
5. Pulling manifold to look for any debris.
During this process, speaking with my builder who I presume will be taking care of me (although hopefully the above stuff I'll just be able to get done myself and get back on the road soon unless other bad things happened).
If you've got more suggestions, bring them on.
