08-15-2003, 10:18 PM
Ca
Cobra Make, Engine: Classic Roadster 427, 446 cu in Iron Eagle stroker, Trick Flow "R" heads, Comp roller, Edelbrock Thunder 800 cfm, Eaton posi, Richmond 3.27, Tremec TKO 600
I recently sold a 1985 Mustang and understood that it was the last year for any Ford to have a carbureted engine. I have a 1986 van with a 351W and it's injected... Don't know if that means anything, but I'd be suspect of any engine in a 1989 that had a carburetor on it unless it was a swap. Check numbers...that's the only way to tell anything for sure!
