Thread: Mcleod spacer?
Old 08-17-2003, 07:30 PM
Tommy's Avatar
Tommy Tommy is offline
Scott S -
Let me add a little more on the chance it may prove helpful. Assuming you have a McLeod bolt-on hydraulic TOB, it is critical that when everything is installed, the distance between the TOB surface and the clutch fingers is correct. This distance can be affected by four things.
1. The depth of the bell housing.
2. The type of clutch.
3. The location of the face on the transmission where the TOB is bolted.
4. The depth of the piston in the TOB.
Your question about a spacer between the TOB and the transmission addresses item 3. But, the size of any spacer must be compatible with the other three dimensions. If I were trying to solve the problem, I'd install the clutch and bell housing, and then measure the distance from the clutch fingers to the back of the bell housing. Assuming the face of the transmission aligns with the back of the bell housing, I now know how deep the TOB has to be. I'd then call McLeod technical support and ask them which TOB and piston was correct for that depth. ... Good luck.
Tommy
Previously owned EM Cobra
