The differential will be identical to the current product in fact it will be supplied by SAI through our current resources. We are looking at the 8.8" Ford with CVs in place of half shafts but feel that through quantity we can get the original diff down to an affordable level. The uprights as well as upper and lower control arms are interchangeable with the originals which quite honestly means current owners of CSX4000 Cobras can upgrade to the new suspension. The only change to control arms is the front upper design that was changed to accommodate an improved ball joint design. The frame itself has not changed from the original configuration and the body is built to the same data as the original although we have made it symmetrical from left to right.
R Brent Fenimore
