Old 08-21-2003, 02:15 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Cast gear means the gear is cast on the cam when it is made..instead of being pressed on and made of alloy at a later date. With the alloy cam gear, the dist gear has to be made of a softer metal, so that it wears and not the cam gear.....thus my saying it's easier to replace a dist gear than a cam gear. With the cast gear you can use a steel dist gear and never have to worry about changing the gears
Jack
XSSIVE .....
