Old 08-21-2003, 04:49 AM
BillE Which system are you looking for? I throttle body or Stack kit that looks like webers. If it is webers, TWM is they close to orginial webers in looks. VeryCoolParts sell a machined set up also. The ECM is what you eed to look at. See what kind of control you have for the motor. Batch fire or sequential fire for the injectors. Timing and fuel control per cylinder. Cam and crank sensors? one or both. Relay contols for fuel, coolant fans, NOS, wide O2 sensor readings, If you are running a large cam you will need this to get good running motor at WOT. You should buy a Fuel injection book and do some reading so you understand whats needed. You may need a 286 laptop for your system to program. Kinsler also sell a kit that looks like the old injector setup for alcohol. I have a F.A.S.T system with a 1200 cfm accell throttle body. It's a great system. The intake I machined myself for the injectors. There is nothing like FI for driving. It will work just like your other cars in the driveway, getin,turn the key, and Vroom, no worrys. You will need to do some extra wiring and large fuel lines for the electic fuel pump. I mounted my ECU under my dash with the MSD. Good luck Rick Lake
