So what I am hearing from you guys is that a cast gear is fine with a non-roller cam/tappets...
Mine is not, standard hydraulic lifters.....RPM Performer Cam.....if I am correct from all of you I should be ok with the standard cast gear then?
....only need the steel gear if you have a roller cam/tappets or a cast cam gear...
