Old 08-21-2003, 10:59 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default I hate carbs
Under strong lateral G force (like a quick U-turn) my Demon shuts down. The motor wants to die....In addition most non-poly carb gaskets are affected by modern (EPA regulated) fuels. Carbs in my opinion are basically obsolete.
IF you can get your EFI tuned properly, it should be a very long term, trouble free install. For this reason (and emissions regulations of course) all modern car manufacturers use EFI. The problems with getting it initially tuned, as fixit states, is the only problem in my opinion. This is because the aftermarket manufacturers are not on the warpath to make such installs easy. Just poor business practices (neglect of suitable software creation due to lack of R & D) in most cases.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
