Old 08-21-2003, 05:23 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
MSD ships its distributors with cast iron cam gear and is intended for use with cast iron hydraulic (or solid) lifter camshafts. The dist usually (mine did) has a tag on it warning the end user to change the distributor gear to a steel gear if the engine has a roller cam which is made out of steel, not cast iron.
If you have a roller cam specially made with a cast iron cam gear, than use a cast iron distributor gear. Don't know of any Ford roller camshafts that can be made with cast iron gear.
