ERNIE - - -
I RECENTLY CHANGED FROM A 15" TO A 14". THE REASON FOR THE CHANGE WAS MY ORIGINAL (MAKE THAT "FIRST") WHEEL WAS DAMAGED IN THE EXPLOSION.
I GOT THE NEW ONE AT THE RAFFLE AT SPRING FLING.
IT'S ON MY ERA COBRA - NOT THE EXCALIBUR. I IMMEDIATELY NOTICED A SLIGHT DIFFERENCE IN STEERING. IT FELT A LITTLE QUICKER BUT ALSO MORE PRECISE. THERE IS NO DISCERNABLE INCREASE IN TURNING EFFORT.
BIGGEST NOTE WAS WHAT SEEMS TO BE A LOT MORE ROOM IN THE COCKPIT.
I WAS REALLY SURPRISED BECAUSE I WASN'T EXPECTING ANY PERCEIVABLE DIFFERENCE.
GIVE IT A LOT OF THOUGHT BEFORE CHANGING OUT THE EXCALIBURS RACK FOR A POWER RACK. IF YOU DO AND GET A SMALLER WHEEL YOU WILL ALMOST SURELY NEED A BIG CO-PILOT ON BOARD TO HELP YOU STEER. YOU WON'T HAVE TO TURN IT VERY MUCH TO MAKE SOMETHING HAPPEN AT SPEED BUT SLOWER SPEEDS IT WILL FEEL LIKE IT HAS A GRAY DOG PAINTED ON THE SIDE.
BEST POLICY IS USUALLY "CHANGE ONLY ONE THING AT A TIME" AND MEASURE THE RESULTS. ANOTHER GOOD POLICY IS "START WITH THE CHEAPEST OR EASIEST THINGS FIRST". REGARDLESS OF WHICH ORDER THINGS ARE CHANGED - - IT WILL ALWAYS BE THE LAST THING YOU TRY THAT WORKS.
Y'ALL HAVE A REALY GREAT DAY.
BLACKJACK
It's impossible to make anything FOOLPROOF - - Because FOOLS are so ingenious.
