You can use mine. It may not fit a SPF (is the spf pattern the same as the Trigo pattern, the wheels are slightly different) Also Mine is a 5 lug on 4.5 and 5 lug on 4.75 with .750" pins. You may have 6 pin .500" studs.
It shouldn't be needed if you already have them installed as the initial fit is the most critical, you won't need to "re adjust" the pins if you put the RF and LF as well as the LR and RR back where they came from. 707.235.6639 (Solano Co.) Very close to Turk.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
