Adhesive for heat insulation??
I am in the final stage of fitting the aluminized matting for heat insulation on the outside of the foot boxes. I will use a thin stainless steel metal border about 1/2" wide around the perimeter however I need some sort of adhesive to keep the main portion of the matting attached to the flat areas of the fiberglass. Is regular 3M or similar spray ok? Or is there somthing more specialized that will not be affected by the heat from the headers.
Thanks
Rick
