Old 08-24-2003, 01:16 PM
Whaler Whaler is offline
All fuses pulled and no diff. Last thing I went to pop off was the 4 pin plug on my external voltage reg and that was it. No more drain.
Its showing 2 amps now with the regulator plugged in
Likely stuck on and its one of the cheap ones not a Ford OEM
Tomorrow I will go get a Ford jobbie.
I guess these guys are solid state not mechanical so tapping it shouldn't unstick it. Charging was/is fine at 13.8 to 14 volts.
Tim
