C-4 Suspension
I am changing my front suspension from the original fiber spring/sway bar to coil/over Aldan adjustable shocks. I have the E-M with a 502 GenVI/ 6-speed and all C-4 suspension. The front end was way to "stiff" using the stock set up so I am going with coil/overs and 300 lb springs to start with. Has anybody already done this and if so, what spring did you use?
Thanks, Jim
