Old 08-26-2003, 08:28 PM
Ray R Ray R is offline
I almost forgot I asked this question. As it turns out, I replaced the stock type waterpump with an Edelbrock unit. The stock pump had fixed hose connections, the Edelbrock has threaded fittings. so I was able to use a 90degree fitting for the water pump hose to the intake, and although the clearances were fairly close, it fits GREAT! Really looks like it should! I just used a short U shaped hose for the connection. If anyone else is facing this problem, I'll email a photo.
