Old 08-27-2003, 09:42 PM
johnd9 johnd9 is offline
Default Thanks
To both of you. I am looking at the Edelbrock Performer RPM manifold, doing a 5 way valve job (I think that is what he said), and installing one of two cams.
1) Lunati 242/258 duration @ .50 and 535/535 lift
2) Comp Magnum Hydraulic Flat Tappet cam - model 292H with a 244/244 duration and .560/.560 lift.
Which would you suggest of those two cams being that I want the most driveable HP increase I can get while keeping it on pump gas? What do you think of the valve job...is it worth it?
Thanks again and where are you located in Northern California? Im from Healdsburg...
John
