If the stutter is only around certain RPM ranges I would go with ignition/wires/plugs. If constant you may want to check valve adjustment as you might have something coming loose there. Any noise associated with it?
You could always just swap that wire with one from the other side and see if the pop moves with it. The pop is probably raw fuel detonating in the pipes.
