Old 08-31-2003, 10:51 AM
LateApex LateApex is offline
Cobra Make, Engine: 2003 Ford Cobra Mustang
Send a message via ICQ to LateApex Send a message via AIM to LateApex
Originally posted by Brent Mills
Pat, I didn't think to check what the clearance was after it gets out of whack, but it's considerable, as I can move the rocker by hand and know there's too much clearance. As for warm to cold, it seems to vary by .002 - .003 across the board (checked that this morning after I adjusted warm last night).
Brent, if they are spot on when you adjust, and then out of whack after a ride, my guess, and this is only a guess, is that prehaps the jam nuts are not tight enough and letting the set screws move while you drive perhaps. I know you said they are tight when you recheck, but how else could the clearances change after you drive??
no signature
