  #48 (permalink)
Old 09-01-2003, 08:32 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Brent,
SCOBRAC has the same rockers as you have He might give you some hints as to the correct pushrod size. But in case of a missmatch of ball and adjuster cup, both are hardened and should wear out slower than appears to happen in your case.
Unless of course the adjuster is not hardened or not done correctly and wearing off. Look at how the adjuster cup is worn. Nice shiny all around or with rough spots somewhere.
I hope this is what is wrong, because its an easy fix.
The other culprit could still be your cam.
And that is another matter.
Good luck again !
Steve
