Old 09-02-2003, 03:20 PM
flipper35's Avatar
flipper35 flipper35 is offline
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Mine was solid as a rock at speed until I changed the ride height. I had it re-aligned because it was slightly toed-out after raising the front and it is back to stable. If you are getting front end lift you may be going from a slight toe-in to a slight toe-out. Something easy enough to check.
Brent Dolphin
