DV, here is the old thread.
http://www.clubcobra.com/forums/t241...-&pagenumber=2
While you do not state large discs will break suspension parts, you do recomend using tubular pieces. Breakage was disucssed earlier in the thread so I assumed your recommendation of tubular pieces was a confirmation.
So, will a Mustang II stock setup with good ball joints hold up with a 12.19 rotor?? I have to believe the 12.19 wilwood kit is virtually the same as the heavy duty kit (10.75 rotor) except for different bracket and of course larger rotor.
