Old 09-04-2003, 07:28 AM
PSB's Avatar
PSB PSB is offline
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Here's a link to the engine section of my build site: http://members.cox.net/petescobra2/engine.htm
I bought all the parts for my engine and had a local engine builder put it together. I paid about the same as a crate motor, but I got to choose the parts. I also got to watch him put the engine together and ask a lot of questions so I can put the next one together.
I went with a hydraulic roller cam. I gotta disagree with Tony about a solid lifter cam. I would not go with a solid lifter cam for a street car, as a solid lifter valvetrain requires constant adjustment. Hydraulic lifters need to be adjusted once when you install them. Especially if you go with solid lifters, make sure your lifters, cam, and valvesprings are matched or you will destroy your cam in short order.
My 408W:
1984 351W block
Scat 9000 crankshaft
Scat forged H-beam rods
Probe Industries Forged Al pistons
Balanced rotating assembly
Total Seal rings
Clevite bearings
Melling standard volume oil pump
Comp Cams custom grind roller retrofit camshaft
FMS roller conversion kit
FMS lifters
Scorpion 1.6 aluminum roller rockers
AFR 185 heads
EFI System:
Trick Flow 351W Intake
Accufab 75mm Throttle Body
Pro-M 75mm Mass Air Flow sensor
36lb injectors
Vortec fuel rails
FMS wire harness
1991 Mustang computer with TwEECer tuner
1993 Ford truck distributor w/steel gear
Estimated HP: 500hp/500 ft/lbs torque
Pete
